05-28-2008 04:31 AM - edited 03-18-2019 09:00 PM
Hi Guys,
I have 4.1.3 SR5 and after a DN was deleted, calls are still ringing through to it. I have seen other posts with a similar problem and they suggest there is a bug for this for which i need the I.D. I have tried searching for it but cannot find it. Also, can you confirm a reboot will fix this for now.
05-28-2008 12:25 PM
repost of prior summary post provided by another poster:
Replied by: rob.huffman - TELECOM ANALYST, MOUNT ROYAL COLLEGE - Feb 28, 2008, 7:36am PST
Hi Chris,
Not this again eh :) I beleive the problem is related to a bug in the sr5b Service Release. I know that this doesn't fix this problem in the short term (there are some ideas in the attached threads), but long term, upgrading to the latest 4.1(3) SR should fully alleviate this problem. Here are three similar threads with the crazy Partition issue;
I'm sure that you are sick of having these problems everytime you go to do a simple change.
Hope this helps!
Rob
05-28-2008 05:48 PM
Hi Bruce,
Just to add a little to the good info from David;
CSCsj30852 Bug Details
CM 4.x - Inactive or Unassigned DN with CFA still forwards calls
Symptom:
Calls placed to a DN that has been deleted from a phone are forwarded to the CFA destination set on the DN when it was deleted.
Conditions:
This was observed in CM 4.1(3) sr5b
A phone has a DN assigned to it and the phone has a CFA destination configured. The DN on the phone is deleted from the phone, but CM still routes calls to the CFA destination
Workaround:
Add the DN back to the phone, remove the CFA setting and update the phone. This will remove the improper CFA and the DN can then be removed without this issue. Status
Fixed
Severity
1st Found-In
4.2(3)
4.3(1)
4.1(3)SR5
Fixed-In
4.3(1.80)
4.3(1)ES10
4.1(3)ES119
4.2(3)ES39
Hope this helps!
Rob
