web vpn links not showing
May 28th, 2008
Hi All,
I am running an 871 Router with IOS version 12.4(15)T3. I setup a SSL VPN connection and everything works fine. I added a few links that show up after the user authenticates (the protal page). The links work fine in IE6, but in IE7 and Firefox the links do not show up at all. Any ideas on how to overcome this? Thanks.
Farrukh Haroon Wed, 06/04/2008 - 06:51
That bug pertains to the VPN conentrator and not the IOS?
I am facing the exact same issue with a customer. IOS WebVPN does not display Administrator defined url-lists. I tried both IE 7.0 and Mozilla Firefox. In IE I was not even able to create Personal Bookmarks using the Add button. However the ones I created in Mozilla showed in IE. I could see them in the XML file in the ASA flash:/webvpn/webvpn/name.xml
CIFS-url-lists are showing perfectly on both IE/Mozilla.
Platform: 2821
IOS 12.4(15)T4 - Advanced IP Services
Farrukh
