05-28-2008 04:51 AM - edited 03-11-2019 05:51 AM
i'm new to cisco's asa and trying to get used to it. it's not a real problem i have, which detains me from productive work but i'm just snoopy about this. on my cisco 871, when i do a
dir nvram:
i see a file called startup-config. but i can not find it on my asa 5510. i have a disk0-1:, flash: and system: but nowhere a startup-config. but it must be somewehre because a
copy tftp startup-config
is working somehow and does what i expect. furthermore, where are the cryptographic keys stored. the same issue. i can not find them. maybe someone of you is able to point me to this. thanks.
ct,
06-03-2008 06:26 AM
The startup configuration for single mode or for the system in multiple context mode is a hidden file in flash memory. From within a context, the location of the startup configuration is specified by the config-url command. For example, if you specify an HTTP server for the config-url command and then enter the copy startup-config running-config command, the security appliance copies the startup configuration from the HTTP server using the admin context interface.
Also check the details about the commands "copy" and "configure-url" in the links below: 1)COPY--http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/c4.html#wp2104587
2)CONFIGURE-URL----http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/c4.html#wp2100481
05-28-2014 03:31 AM
Good day,
I am also curious where a startup-config is being stored.
I try securely download startup-config to windows C:\Temp file, but FW is disconnecting pscp request. When I try to download any file located in disk0:/ I am able to.
Please advice how can I download startup-config with pscp.
Thank you
