CDR Alerting Questions
May 28th, 2008
UCM 5.1(3)
Two questions:
1) How do you configure alerts for CDR? I have alerts configured via RTMT, however I've been getting separate alerts from the email account I configured in CDR Analysis & Reporting (via SYSTEM>SYSTEM PARAMETERS>MAIL PARAMETERS). I am looking to configure a few email addresses and can't find where it was set up.
2)I received an alert "The number of records in the CAR database size had breached the 2 Million Mark (1500000 records). The number of records in the CAR database was 1500208. After purging, number of records in the CAR database with 1500208 still crosses 2 Million Mark, hence CAR loader was stopped. Please lower the Max and Min Number of Days of Records from the Auto-Purge page ASAP, to allow deletion of older records to keep size further below the 2 Million Records Mark." This makes no sense as simple math will tell you 1,500,000 is less than 2 million.
Overall Rating: 1 (2 ratings)
Jaime Valencia Wed, 05/28/2008 - 06:21
number of records in the CAR database was 1500208 > 1500000 records (2 Million Mark)
u can try setting the alert to a mailer
javalenc
if this helps, please rate
Brian Carscadden Wed, 05/28/2008 - 06:26
Come again ... how is 1500000 considered the "2 Million Mark" ?
I need much more detail on the email alerting.
They're not billing by the letter in these forums, feel free to elaborate. Thanks!
Jaime Valencia Wed, 05/28/2008 - 06:41
the limit has always been set to 1,500,000 records by default, also in all previous versions in case you had not worked with them
From docs:
If CDRs accumulate to a configured maximum, the system removes the oldest CDRs along with related CMR records once a day. The default maximum specifies 1,500,000 CDRs.
javalenc
Brian Carscadden Wed, 05/28/2008 - 06:45
Thanks for the follow-up. But can you explain why "1500208 still crosses 2 Million Mark"?
1,500,208 is less than 2,000,000 no?
