Administrator user in CCM 4.2
May 28th, 2008
For security reasons in Windows 2000 it is a sugestion to rename the "administrator" user and then to create a new a"dministrator" user with lower privileges than an Administrator.
It is recommended to do it in CCM? does it affect the telephone service or the administration of the CCM?
thanks everybody
Jaime Valencia Wed, 05/28/2008 - 06:51
  • Cisco Employee,
  • Hall of Fame,
    2011
usually it's only recommended to change the built in Administrator username, but when performing upgrades you need to set it back to Administrator.
you can create other users if they need to access the OS, just make sure nothing from CUCM has to do with them, or any service running on the server
javalenc
if this helps, please rate
