05-28-2008 06:48 AM - edited 03-11-2019 05:51 AM
I would like to remove my passive unit from my current active/passive setup. Other than just unplugging the FOLink and turning off the unit is there a safe method of removing it from the pair? Keep in mind this is a production firewall housing lots and lots of websites and content behind it so I can not afford even a minute of downtime. Kind of in a rush to get this figured out, so thank you in advance to anyone who responds, I appreciate it.
Solved! Go to Solution.
05-29-2008 08:52 AM
that's correct.
clear configure failover removes all failover commands.
clear configure ... will remove all commands related to which command you issue next.
eg clear configure static, clear configure nat, clear configure tunnel-group tunnelgroupname
05-28-2008 10:04 AM
Sorry for the bump, but I just found out I need to do this tomorrow afternoon at the latest.
Cheers
05-29-2008 04:27 AM
Ok I have about 4 hours until my deadline now.
If I load up my primary unit and enter the command "no failover" will that be adequate to remove the secondary unit from the mix without having my primary mess up?
I have set up active/passive a few times, just never had to remove the secondary unit while the primary was in production.
05-29-2008 06:47 AM
turn the secondary off
issue "no failover" on the primary -
05-29-2008 07:27 AM
Thanks a lot, after issuing the 'no failover' command am I am assuming you mean to remove the actual lines that reference the failover setup when you say "clear configure failover".
Thanks a lot!
05-29-2008 08:52 AM
that's correct.
