Holiday script for Unified ccx 5.0
May 28th, 2008
I'm new to scripting and was looking for some help with a holiday script.I have questions like which is easier (XML or DB Subflow) and how to you create them.
And where are they stored. Hope this makes sense.
Thanks for the help
regi_firnanda Wed, 05/28/2008 - 19:45
I think there's a script example for what you are looking for in the script repository that you can download from Cisco's website.
About which one is easier, I think that XML subflow is simpler because you can create and modify the XML file just by using Notepad.
Abdulbaseer Mohammed Fri, 05/30/2008 - 21:59
  • Silver, 250 points or more
Hello Bill,
I have a holiday scrip feel free to use or refer to it. Any questions don't hesitate to conatct me.
Attached is the script.
Please rate any helpful posts.
Welcome to scripting world and happy scripting.
Baseer.
