Unity Connection Call Handler
Answered Question
May 28th, 2008
I have created a System Call Handler in Unity Connections after the message plays with the call in put options a 2nd message plays that says plays saying "record your message at the tone."
How do i turn this 2nd message off, I do not want callers to be able to leave a message on this call handler
Correct Answer by Naveen Raj Janardhan about 8 years 8 months ago
First make sure that you have the message recorded at either the "greetings" page or the "profile" page.
for the message "record your message at the tone." NOT to show up, goto greetings on the left pane, after the greetings page shows up, click on the radio button "Send Caller to" and select "Hang up" from the drop down menu
Overall Rating: 5 (1 ratings)
Correct Answer
Naveen Raj Janardhan Wed, 05/28/2008 - 08:57
Rob Huffman Wed, 05/28/2008 - 09:03
Hi Andy,
From the Greetings page for the Call Handler, uncheck the default Take message after greeting. Select the Send caller to button and select something else. If you are going to do this, it is good to route the caller to some type of goodbye handler instead of just hanging up. (Just seems a tad more polite)
Hope this helps!
Rob
Rob Huffman Wed, 05/28/2008 - 11:11
Hey Naveen,
No worries mate :) It's all about the caller/customer after all.
Take care,
Rob
