OSPF - Route Filtering Recommendations
May 28th, 2008
We are filtering routes inbound using an OSPF setup. We are filtering the routes populating the routing table, we do not need to stop the routes entering the OSPF database.
We currently use standard numbered ACL's (1-99) linked to a route-map to achieve this. I am looking at other options in order to provide greater flexibility i.e. named ACL's, prefix-lists etc.
Can anybody provide any suggestions/recommendations as to the most flexible yet robust method?
I am running this on a 3750 with the Enhanced image.
Cheers,
Andy.
amritpatek Tue, 06/03/2008 - 10:44
  • Silver, 250 points or more
The OSPF Inbound Filtering Using Route Maps with a Distribute List feature allows users to define a route map to prevent Open Shortest Path First (OSPF) routes from being added to the routing table. In the route map, the user can match on any attribute of the OSPF route.
For the configuration follow the URL :
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_ospf_inbound_ps6922_TSD_Products_Configuration_Guide_Chapter.html#wp1040908
starmantwo Tue, 07/08/2008 - 05:57
I was looking to implement something like this. But arent you able to filter with just an acl and distribute list, why is a route map needed?
