Unity 5.x on Dell?
May 28th, 2008
Have Enterprise customer that standardized on Dell servers. For appliances (UC Manager) others are acceptable. But for systems running Windows, they have policy that it must run on a Dell. Have found references in Cisco docs for 5.x that say Dell remote management card is supported (I would think this means the Dell server). Nowhere do I find a statement that "customer provided servers, i.e. Dell, are not acceptable".
Anyone know the answer and could point me to some kind of authority?
Ginger Dillon Wed, 05/28/2008 - 10:46
Hi -
Here is the current Unity supported platforms list - http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd802132ef.pdf
We're an HP shop and upgrading our existing Unity bridge server, new hardware and Windows 2003 compatible. I checked with TAC to see if I could use a comparable HP server as the only certified supported platform listed in this same doc was an IBM workstation server. Well ... we're getting the IBM server :-)
Ginger
testeven Wed, 05/28/2008 - 11:58
When installing servers you must choose one from Supported HW list, if it's not then don't install it. It can probably work if it meets the specs, but as it's not supported when it fails Cisco TAC will not support it.
kbelter Wed, 05/28/2008 - 12:16
I am assuming that you are referring to the platform configuration disk (which sets up bios/raid and loads windows). If you need certain languages, the documentation says to setup server manually using the skrink-wrapped Microsoft standard Windows Server install disk.
As to TAC support, this is a major reason I am asking.
Jaime Valencia Wed, 05/28/2008 - 17:53
the card indeed shows but as: Supported Optional Hardware
Dell Remote Assistant Card, version 2.0 and later.
Overview: Dell Remote Assistant Card Version 2.0
http://support.dell.com/support/edocs/network/DRAC2/overview.htm
The Dell Remote Assistant Card (DRAC) version 2.0 is an add-in server management card
but the server support from Cisco is what shows up in the link that has already been provided of supported platforms for Unity.
you can go to www.cisco.com/swonly and see if the server has the EXACT specs as an MCS. i do mean EXACT because the PCDs look for what's on the link
javalenc
if this helps, please rate
