Policing not working
May 28th, 2008
i want to implement LLQ for my users. I want that when specific user try to access specific subnets it gets
only 8 KBps. I have cisco router 2821 with two FE ports.
I have made the following configuration but still not able to restrict the user to 8 KBps, user when try to download
from remote computer, no policing and LLQ comes in action.
below mention is configuration that I made on router.
class-map match-all testclass
match access-group 150
policy-map testpolicy
class testclass
police cir 8000 bc 1000 be 1000
conform-action transmit
exceed-action drop
violate-action drop
interface FastEthernet0/0
ip address 10.1.3.1 255.255.255.0
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
service-policy input testpolicy
interface FastEthernet0/1
ip address 10.1.4.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.3.2
ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 100 permit ip any any
access-list 150 permit ip host 10.1.4.3 any
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Router-C#
Router-C#wr me
Building configuration...
[OK]
Router-C#show int
Router-C#show poli
Router-C#show policy-map inte
Router-C#show policy-map interface fas
Router-C#show policy-map interface fastEthernet 0/0
FastEthernet0/0
Service-policy input: testpolicy
Class-map: testclass (match-all)
14 packets, 1605 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: access-group 150
police:
cir 8000 bps, bc 1000 bytes, be 1000 bytes
conformed 1 packets, 243 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
drop
violated 0 packets, 0 bytes; actions:
drop
conformed 0 bps, exceed 0 bps, violate 0 bps
Class-map: class-default (match-any)
315852 packets, 461648032 bytes
30 second offered rate 2000 bps, drop rate 0 bps
Match: any
Router-C#show int
Router-C#show interfaces fas
Router-C#show interfaces fastEthernet 0/0
FastEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 001d.a16c.9b70 (bia 001d.a16c.9b70)
Internet address is 10.1.3.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:27, output 00:00:03, output hang never
Last clearing of "show interface" counters 00:16:00
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
315916 packets input, 461657577 bytes
Received 461 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
167296 packets output, 11153399 bytes, 0 underruns
0 lost carrier, 0 no carrier
Overall Rating: 3 (1 ratings)
michael.leblanc Wed, 05/28/2008 - 13:34
  • Silver, 250 points or more
You have a directional issue.
... matches packets where 10.1.4.3 is the "source" ip address.
A host with this address would reside on the FastEthernet0/1 side of the router, NOT the FastEthernet0/0 side of the router where you have applied input service-policy (service-policy input testpolicy).
Apply the "input" policy to FastEthernet0/1, or reverse your ACE if you want the policy to be applied to FastEthernet0/0.
e.g.:
access-list 150 permit ip any host 10.1.4.3
Change one or the other, but not both.
wasiimcisco Wed, 05/28/2008 - 14:16
Thanks for the reply, I wil change it in the morning and then let u know the effect, one thing more please tell me i m using ethernet interface and ethernet has bandwidth 100 Mbps,
is there any need to change the bandwidth to actual bandwidth like 2 MB, 3 MB that i will get from my service provider.
bcz router will assign bandwidth by seeing the interface actual bandwidth.?????? am i right or
michael.leblanc Wed, 05/28/2008 - 15:00
The interface "bandwidth" command is use for setting routing metrics on the interface.
The policy-map "bandwidth" command used in queueing can reference a specific bandwidth, or a percentage of "available bandwidth".
I find the term "available bandwidth" to be too ambiguous. I'd stick to setting specific bandwidth requirements rather than percentages.
wasiimcisco Thu, 05/29/2008 - 05:33
thanks for the reply, i m configure the policing by modifying the access-list and now it is working fine for me.
But LLQ is not working for me in the same setup
i want user 10.1.4.5 always get 74990 and other user get 8 kbps
i want reservation via LLQ. I configure the following below mention command on router but not able to get the desired result.
version 12.4
class-map match-all testclass2
match access-group 160
class testclass
priority 8
class testclass2
priority 74990
bandwidth 8000
ip nat outside
load-interval 30
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip classless
access-list 160 permit ip host 10.1.4.5 any
FastEthernet0/0
Service-policy output: testpolicy
91678 packets, 5680284 bytes
30 second offered rate 698000 bps, drop rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 8 (kbps) Burst 200 (Bytes)
(pkts matched/bytes matched) 9/612
(total drops/bytes drops) 0/0
Class-map: testclass2 (match-all)
144133 packets, 8696430 bytes
30 second offered rate 898000 bps, drop rate 0 bps
Match: access-group 160
Queueing
Strict Priority
Bandwidth 5990 (kbps) Burst 149750 (Bytes)
(pkts matched/bytes matched) 22/1251
27 packets, 2235 bytes
michael.leblanc Thu, 05/29/2008 - 07:42
If you factor your desired rate 74990 (kbps) by 0.8 (due to the "bandwidth 8000" (kbps) command on your FastEthernet0/0 interface), you will get 5990 (kbps).
This is the value confirmed by your "show policy-map interface fastEthernet 0/0" output:
Queueing
Strict Priority
The output also confirms that you are matching packets.
If you were to set the interface bandwidth command to 10000, you should be able to set the queue bandwidth to the desired 74990 (kbps), but obviously you have set the interface bandwidth to 8000 for a reason.
wasiimcisco Thu, 05/29/2008 - 10:21
I didnt get what you are saying, kindly see my fresh configuration, I wana put restriction on user for certain bandwidth but user is still able to get bandwidth in MB
*May 29 15:25:44.768: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 1247 bytes
version 12.4
hostname Router-C
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool users
network 10.1.4.0 255.255.255.0
default-router 10.1.4.1
voice-card 0
no dspfarm
class testclass
priority 8
class testclass2
priority 5990
class class-default
fair-queue
duplex auto
speed auto
service-policy output testpolicy
duplex auto
speed auto
ip classless
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router-C#
Router-C#sh run
version 12.4
hostname Router-C
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip dhcp pool users
voice-card 0
no dspfarm
class testclass
priority 8
class testclass2
priority 5990
class class-default
fair-queue
duplex auto
speed auto
duplex auto
speed auto
ip classless
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
