CCM5: Backup and Restore shows no status
May 28th, 2008
Hi all,
I have a CCM5 cluster, version 5.1.3.3000-5 here.
When I start a backup, no status is displayed. The status page shoes no information.
After a while, the data is stored on the SFTP server, and the backup is listed in the history as SUCCESS.
I tried to restore such a backup, and it works fine but the restore process also shows no status.
Any ideas?
Thanks in advance
Jörg
Jaime Valencia Wed, 05/28/2008 - 17:35
  • Cisco Employee,
  • Hall of Fame,
    2011
exactly what do you see?
a blank page?
if you press f5 does it refreshes with the current status
javalenc
if this helps, please rate
joergwesely Thu, 05/29/2008 - 01:27
I see the status page, but all fields are empty- as if there would be no backup running at the moment.
