COS to EXP bits mapping
amitbatra
Hi Guys,
theoretically and practicaly the DSCP or IP prec values are copied to EXP bits of shim header.
Does that same applies to when Atom is configured ?? because in Atom the PE receives traffic from CE and that could be vlan tagged. PE imposes the MPLS tag received from egree PE and then imposes the tunnel tag and send it to the egress PE.
are the COS values copied to the appropriate EXP bits at this time ??
Hi Amit!
Thanks. Can you please mark the question as solved if it did? or rate it accordingluy?
Niranjan
16 Replies 16
shivlu jain
Level 5
Level 5
exp bit only understands the dscp, so first yoou have to convert the cos to dscp and then bind the dscp to exp.
regards
shivlu
hi Shivlu!
I would like to counter your argument. It is not necessary to convert the cos to dscp first. The ip pre to exp mapping is the default. But you can use MQC to directly map from the cos bits recieved to the mpls exp bits. Following are the references :
"Note Mapping 802.1p CoS values to MPLS EXP bits is supported using EoMPLS only. " found in ...
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/6500series/76ovwsip.html
This is cat6500 / 7600 documentation.
Also from cisco press :
http://www.networkworld.com/subnets/cisco/042707-ch12-mpls.html?page=10
The Use of MPLS QoS for Ethernet over MPLS
So far in this chapter, the packet for which the QoS was set was an IP packet or a labeled packet. However, in the case of Ethernet over MPLS (EoMPLS), the forwarded packet is actually an Ethernet frame. If the frame is a non-VLAN Ethernet frame, it does not have QoS information embedded. If the frame is an 802.1Q frame, though, the Priority bits (P bits) in the 802.1Q header designate a QoS value. If a service provider carries the 802.1Q Ethernet frames over an MPLS network as in the case of point-to-point EoMPLS or VPLS, it would be nice if he could police the traffic and recolor it, if needed. You can do this in Cisco IOS. You can match the 802.1Q Priority bits in MQC by matching cos values in the class map. In Example 12-11, the EXP bits are set to 1 on the tunnel and VC label on the ingress PE, if the 802.1Q P bits are 1, 2, or 3.
Example 12-11 MPLS QoS for EoMPLS
interface Vlan50
no ip address
mpls l2transport route 1.1.1.1 100
service-policy input foo
class-map match-all foo-class
match cos 1 2 3
policy-map foo
class foo-class
set mpls experimental 1
class class-default
shape average 2000000 8000 8000
Amit, I hope this answers your question!
Cheers!
Niranjan
Hi Shivlu,
i really appreciate your efforts . but EXP bits used prec values. there are only 3 EXP bits where as you have 6 bits for DSCP .
EXP has trouble to cope up with DSCP.
Thats not true that you have to convert them to DSCP and then map to EXP
what niranjan is saying is right.
the reason i asked this question in this forum is , i wanted to confirm this from everybody here and get some more thoughts.
anyways
Thanks niranjan
Hi Amit!
Niranjan
hi niranjan
thanks for your reply because b4 that i really know this thing.
thanks 2 amit also for putting such type of question on forum.
regards
shivlu
Hi Niranjan,
Hope you don't mind for another case that we have facing.
Our CE is a 7606 WITHOUT the SIP so we are doing PFC QOS, the link between CE and PE is a GE with 802.1q encapsulation, so the voice traffic is taking priority queue with COS 5 to PE and PE is a 10K router with MQC QOS configured and matching EF and CS5 for the priority queue and mark to EXP 5 for the up-stream MPLS router.
The customer is seeing CS4 (DSCP 40) for the remote ingress voice traffic, where was doing wrong?
Here is the cos-dscp map from hub CE (COS5 mapped to EF):
njli2pece1#sh mls qos maps cos-dscp
Cos-dscp map:
cos: 0 1 2 3 4 5 6 7
dscp: 0 10 18 26 34 46 48 56
njli2pece1#
The remote CE is seeing CS5 from their PE not EF:
mdhv113ce1#sh policy-map interface
Serial0/0/0:0
Service-policy input: Verify-Dscp
Class-map: check-voice (match-any)
149431 packets, 9923547 bytes
30 second offered rate 18000 bps
Match: ip dscp ef (46)
0 packets, 0 bytes
30 second rate 0 bps
Match: ip dscp cs5 (40)
104578 packets, 6970243 bytes
30 second rate 18000 bps
Is it true that the MPLS EXP is just a header appended to the IP frame and the DSCP value inside shouldn't be touched inside the MPLS cloud?
Hi!
First of all, it is true that the DSCP value shouldnt be touched inside the mpls cloud. All Qos will be done on the exp bits.
For your problem, Since you are using PFC based Qos even on the PE, I am assuming that you have a LAN card facing the CE.
What is the cos-dscp mapping on the ingress PE. I am seeing the mapping on the CE. This is the wrong place. Assuming that the PE is recieving the traffic with vlan tag with cos-5, you should set the cos-dscp map here. This works in the ingress and as I can see, probably you have set the mapping on the egress port of the CE.
Hope this will solve your issue.
If not, please give me more details on the interface configs on the CE1, PE1, PE2, and CE2.
Niranjan
Thanks for the reply.
What is the command to see the cos-dscp mapping from a GSR 10k router, there is no mls qos command?
Here are the config:
Hub CE:
njli2pece1#sh run int gi3/24
interface GigabitEthernet3/24
no ip address
load-interval 30
wrr-queue bandwidth percent 30 20 50
wrr-queue queue-limit 40 30 15
wrr-queue random-detect min-threshold 1 60 80 100 100 100 100 100 100
wrr-queue random-detect min-threshold 2 60 80 99 99 100 100 100 100
wrr-queue random-detect min-threshold 3 99 100 100 100 100 100 100 100
wrr-queue random-detect max-threshold 1 80 100 100 100 100 100 100 100
wrr-queue random-detect max-threshold 2 80 100 100 100 100 100 100 100
wrr-queue cos-map 2 3 6
wrr-queue cos-map 2 4 7
wrr-queue cos-map 3 1 3
wrr-queue cos-map 3 2 4
mls qos trust dscp
no cdp enable
end
njli2pece1#sh run int gi3/24.112
interface GigabitEthernet3/24.112
encapsulation dot1Q 112
ip vrf forwarding r1-aiggs
ip address 68.139.194.194 255.255.255.252
ip flow ingress
ip flow egress
no cdp enable
end
Hub PE:
worge01>show config | b GigabitEthernet4/1.49659
interface GigabitEthernet4/1.49659
ip vrf forwarding V127453:AmericanInternational
ip address 68.139.194.193 255.255.255.252
ip access-group 101 in
no ip redirects
no ip unreachables
no ip directed-broadcast
no ip proxy-arp
ip mtu 1500
plim qos input map cos 5 queue low-latency
service-policy input DSCP_CE-PE_ETM_G=5008K_R=300M
service-policy output DSCP_PE-CE_282000K_gsr_6Q !
worge01>show policy-map DSCP_CE-PE_ETM_G=5008K_R=300M
Policy Map DSCP_CE-PE_ETM_G=5008K_R=300M
Class class-default
police cir 300000000 bc 37500000 be 37500000
conform-action transmit
exceed-action drop
service-policy DSCP_CE-PE_ETM_G=5008000_gsr
worge01>show policy-map DSCP_CE-PE_ETM_G=5008000_gsr
Policy Map DSCP_CE-PE_ETM_G=5008000_gsr
Class dscp_EF_ipprec_5_5Qs
police cir 5008000 bc 626000 be 1252000
conform-action set-mpls-exp-imposition-transmit 5
exceed-action drop
Class dscp_AF4x_ipprec_4_5Qs
set mpls experimental 4
Class dscp_AF3x_ipprec_3_6_7_5Qs
set mpls experimental 3
Class dscp_AF2x_ipprec_2_5Qs
set mpls experimental 2
Class ip_best_effort_BE
set mpls experimental 0
worge01>sh config | b dscp_EF_ipprec_5_5Qs
class-map match-any dscp_EF_ipprec_5_5Qs
match ip dscp 40 46
Remote CE:
mdhv113ce1#sh run int s0/0/0:0
interface Serial0/0/0:0
no ip address
encapsulation frame-relay IETF
load-interval 30
service-policy input Verify-Dscp
service-policy output TypeB-Remote-QOS-Out
end
mdhv113ce1#sh run int s0/0/0:0.100
interface Serial0/0/0:0.100 point-to-point
ip address 159.24.187.178 255.255.255.252
ip flow ingress
ip flow egress
snmp trap link-status
frame-relay interface-dlci 100 IETF
end
Remote PE:
ptnes05>show config | b Serial8/0/2.1/28:1.20505
interface Serial8/0/2.1/28:1.20505 point-to-point
ip vrf forwarding V128431:AmericanInternational
ip address 159.24.187.177 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
service-policy input DSCP_CE-PE_ETM_G=448000
service-policy output DSCP_PE-CE_1536K_6Q
ptnes05>show policy-map DSCP_PE-CE_1536K_6Q
Policy Map DSCP_PE-CE_1536K_6Q
Class class-default
shape 1536
service-policy DSCP_PE-CE_1344000_to_120M_6Q
ptnes05>show policy-map DSCP_PE-CE_1344000_to_120M_6Q
Policy Map DSCP_PE-CE_1344000_to_120M_6Q
priority
police percent 50 25 ms 0 ms conform-action transmit exceed-action transmit violate-action drop
ptnes05>sh config | b dscp_EF_ipprec_5_5Qs
match ip dscp cs5 ef
Hello Frank!
I am not very comfertable with the 10K configuration. But probably since it is a router and doesnot support mls qos commands on the interface, you will have to apply a policy map at the ingress to match based on cos and mark the dscp accordingly.
Also, on the PE ingress policy, under class-map match-any dscp_EF_ipprec_5_5Qs
match ip dscp 40 46 <<<<<<
Why do you have 40 and 46?
For the time being can you remove 40 from this, and check the output of the command
" sh policy-map interface Gi4/1.49659 " ??
If the counters are not increasing for this class, then it would confirm that the packets recieved from the hu-CE are not marked to DSCP EF.
So, if the DSCP is not set to EF by the CE ( as I am suspecting,) then the counters for the Class dscp_EF_ipprec_5_5Qs would not increase.
But that will not explain why the remote CE is getting traffic with DSCP40 , unless the original traffic being sent has dscp40 already set on it, or the non-pe-connected port has a default cos-map kick-in which might be setting the dscp to 40.
If tthis solution is not working , I could you please let me know the results of the above test? The stratagy would be to find out at which place the DSCP is failing ( not EF) .
Niranjan
The PE was managed by our core group and I have asked them to separate two line instead of put 40 and 46 together but got rejected.
I have asked the customer to schedule a troubleshooting session to SPAN on the CE interface to see what DSCP is sending out and will go from there.
What is the default mapping from a PFC COS5 to MQC DSCP on ethernet .1q link between 7606 and 10k GSR?
Hi!
The mapping that you are talking about should depend on the incoming map/trust conditions on the ingress port of the CE. Is any trust / trust ip phone configured on the ingress port of the CE device?
Can you check applying the cos map on the ingress port ( the non-PE-connected port of the hub CE.)?
The current cosmap on the CE on the CE-PE link is not doing any dscp mapping and neither is the PE. So for the remote to get packets marked with dscp40, the only way is that some config trust/cos-map settings on the ingress of the CE is affecting.
Niranjan
Niranjan
There is no cos mapping on the link between CE and LAN switch, here is the config:
njli2pece1#sh run int gi4/1
description To RPUSNJLI2PE-1 GE4/1
switchport
switchport trunk native vlan 150
switchport trunk allowed vlan 150,151
switchport mode trunk
mls qos trust dscp
channel-group 1 mode desirable
end
As I understand the trunk port is doing FIFO and won't do anything even with cos-map, is it correct?
Which trunk port do you mean?
The incoming connected to LAN is doing FIFO and not applyng any cos-map as i see it.
The port connected to PE is doing the queuing but not applying cos map for the egress traffic.
The mls-qos trust on the lan connected port explains the dscp mappinp of CS4. Probably the traffic coming in is already marked with 4.
The solution for your issue can be :
1. to implement class-map at the ingress on the PE to map from cos to DSCP EF.
2. To verify the DSCP recieved on the CE from LAN and use DSCP-Mutation to map the traffic to EF.
3. Do nothing as the CS4 as well as EF traffic is getting the same treatment in the MPLS core as the class map on the PE matches either 40 or 46.
Niranjan
hi!
Can you please rate the post if your issue is solved? Or do let me know if you are still facing any problems.
Niranjan
