Presence asking for password after install
rraver
I just got done doing the presence installation and did the configuration tasks on the CUCM 6.0 BE we have. It's asking for the CUCM information and I gave it the hostname, IP, and password of it but it's not liking the password. Where is it pulling this password from? They are on the same subnet with nothing in between so communication should be fine, it passed it's network test. I don't know what password it's asking for, any help?
rraver
The log on RTMT I get is
May 28 17:45:21 tweak Notice sshd(pam_unix)[18207] : authentication failure; logname= uid=0 euid=0 tty=NODEVssh ruser= rhost=presence.part.net user=sftpuser
The screen on presence says:
"CUP nodes must specify information to connect to the cluster's CUCM publisher for network inclusion:"
Host Name:
IP Address:
Security Password:
Confirm Password:
have you added the CUPS under applications servers in CUCM config?
javalenc
if this helps, please rate
java
yea, it just asked for the hostname though. I didn't use the fqdn I just used the hostname.
In more detail I used:
presence
instead of
presence.part.net
