Order of Shutdown VPN Concentrators
May 28th, 2008
We have two 3005 VPN Concentrators. We set them up as Load Balancing. We need to shutdown the VPN Concentrators because the building needs to shutdown the power. What are the orders of shutting down and bringing them back up? Would you bring down the Secondary VPN Concentrator first, then bring down the Primary VPN Concentrator? To bring them up, would you bring the Primary VPN Concentrator first, then the Secondary VPN Concentrator?
Thanks.
Overall Rating: 5 (1 ratings)
bwilmoth Tue, 06/03/2008 - 10:28
  • Silver, 250 points or more
you shut down the VPN Concentrator before you turn power off. If you just turn power off without shutting down, you may corrupt flash memory and affect subsequent operation of the system.
This guide has informationon the procedures to shutdown the VPN concentrator
http://www.cisco.com/en/US/docs/security/vpn3000/vpn3000_47/administration/guide/sysrbt.html
