Serial Cable
May 28th, 2008
I currently have 2 2501 routers and 2 2503 routers, i want to connect all 4 together. is this the cable i would use 4 of these?? http://cgi.ebay.com/Cisco-Crossover-Serial-Cable-3-ft-DB60-DTE-DCE-M-M-2pk_W0QQitemZ360055917597QQihZ023QQcategoryZ101282QQssPageNameZWDVWQQrdZ1QQcmdZViewItem thanks=)
Edison Ortiz Wed, 05/28/2008 - 19:57
  • Hall of Fame,
    Founding Member
Yes, that's the cable.
__
Edison.
shivlu jain Wed, 05/28/2008 - 21:25
  • Silver, 250 points or more
yes you can use the cable, always remeber one thing when you want to connect the two routers back to back in that case one router will become the DCE and another will become the DTE end. So always look for the DCE - DTE cable.
regards
shivlu
