AXL Beginer
May 29th, 2008
Dear Sir,
I am an AXL Beginer Developer, I need any simple example using AXL to begin with.
I need to know format of the file, is it .asp file or xml file?
marwa_ads Mon, 06/02/2008 - 00:34
Dear Stephan,
Thanks alot for your help, I read the java example in the AXL programming guide for CM 4.2(3).. I tried it, but it doesn't work with me, i receive the following error:
HTTP/1.1 401 Access Denied
Server: Microsoft-IIS/5.0
I don't know why... could you help me please..
this is the code:
class main
public static void main(String[] args)
//Declare references
String sAXLSOAPRequest = null; // will hold the complete request,
// HTTP header and SOAP payload
String sAXLRequest = null; // will hold only the SOAP payload
Socket socket = null; // socket to AXL server
OutputStream out = null; // output stream to server
InputStream in = null; // input stream from server
byte[] bArray = null; // buffer for reading response from server
// Build the HTTP Header
sAXLSOAPRequest = "POST /CCMApi/AXL/V1/soapisapi.dll\r\n";
sAXLSOAPRequest += "Host:\r\n";
sAXLSOAPRequest += "Authorization: Basic"+authstring+"\r\n";
//sAXLSOAPRequest += "Authorization: Basic bGFycnk6Y3VybHkgYW5kIG1vZQ==\r\n";
sAXLSOAPRequest += "Accept: text/*\r\n";
sAXLSOAPRequest += "Content-type: text/xml\r\n";
sAXLSOAPRequest += "Content-length: ";
// Build the SOAP payload
sAXLRequest = "\" ";
sAXLRequest += "xmlns:xsi=\"\" xmlns:xsd=\"\"> ";
sAXLRequest += "\" ";
sAXLRequest += " xsi:schemaLocation=\"\" ";
//sAXLRequest += " xsi:schemaLocation=\" http://localhost/schema/axlsoap.xsd\" ";
sAXLRequest += "sequence=\"1234\"> SEP000E7BC54F2A ";
sAXLRequest += " ";
// finish the HTTP Header
sAXLSOAPRequest += sAXLRequest.length();
sAXLSOAPRequest += "\r\n\r\n";
// now add the SOAP payload to the HTTP header, which completes the AXL SOAP request
sAXLSOAPRequest += sAXLRequest;
// now that the message has been built, we can connect to server and send it
socket = new Socket("", 80);
out = socket.getOutputStream();
in = socket.getInputStream();
// send the request to the host 10 AXL Programming Guide for Cisco Unified CallManager 4.2(3)OL-10660-01 Throttling of Requests
// read the response from the host
StringBuffer sb = new StringBuffer(2048);
bArray = new byte[2048];
int ch = 0;
int sum = 0;
while ( (ch = != -1 )
sum += ch;
sb.append(new String(bArray, 0, ch));
// output the response to the standard out
} catch (UnknownHostException e)
System.err.println("Error connecting to host: " + e.getMessage());
} catch (IOException ioe)
System.err.println("Error sending/receiving from server: " +
// close the socket
if (socket != null) socket.close();
} catch (Exception exc)
System.err.println("Error closing connection to server: " +
Thanks alot,
marwa_ads Mon, 06/02/2008 - 02:22
Dear Stephan,
I enabled Basic Authentication in the IIS of the CM, But the error now is changed, the following appears in the debugger:
HTTP/1.1 500 Server Error
Date: Sun, 01 Jun 2008 18:34:04 GMT
Content-Type: text/html
Content-Length: 94
ErrorInvalid access to memory location.
wschochet Tue, 06/03/2008 - 09:20
Here is a handy little page that I use to launch SOAP messages at my Call Manager. You'll want to change the User and Password entries in line 17 as well as the host/name / IP address in line 47 to match your environment. Written by someone much smarter than I....
Jeff Garner Wed, 07/02/2008 - 11:29
Any one know what you need to do to modify this to work with CCM 5.x / 6.x. This works find for CCM 4.x but I get errors with 6.x
jaregalado Tue, 07/08/2008 - 21:14
the URL and port numbers are different for CCM 4.x and 5.x/6.x
For CCM 4.x
For CCM 5.x and 6.x
Jeff Garner Wed, 07/09/2008 - 06:45
Thanks I did get mine working, however I my system did not work with the https://$CCM:8443/axl/ Only https://$CCM/axl/
For some reason my AXL responds on the normal 443 port. I also found that I have issue with the SSL certificate. Because im using msxml2.xmlhttp to post the soap requests, I have to firsy open a browser to the CCM server accept the SSL cert with a warning about the name vs IP, then my post would work...
rameshbalajiv Thu, 07/17/2008 - 10:34
I was trying to use the getPhone.htm file with following sample code provided in the manual:">
xsi:schemaLocation=" axlsoap.xsd">
SELECT * from numplan
But it doesn't give me any values and I can see the "error on page" msg.
Please let me know where/how should I see the results and detect the errors in the XML or HTML.
FYI - this is my first attempt on AXL side of it.
Thank You
Ramesh V.
rgomes Thu, 08/21/2008 - 14:21
I am trying to run this getPhones but I am getting the error "the requested resource CCMApi/AXL/V1/soapisapi.dll is not available.
I am using CUCM 6.1.2 and don't know how to change for it. I changed the line
var reqString = "http://"
var reqString = "https://"
but could not manage to change the port, if needed.
When I access the CUCM via the browser the ccm admin page runs under the 8443 port.
I am getting the same erros on the logs of the CUOM application and I am looking how to troubleshoot to see if some configuration on the CUCM 6.1.2 is missing.
Any help is appreciated. Tue, 03/17/2009 - 05:18
Can you give me the plan how I can run getPhone.htm to retreive info from DB?
Run in browser? Wed, 07/01/2009 - 05:09
Could you answer for my question?
Run in browser?
