Cisco Switch & 3com wireless AP.
May 29th, 2008
Hi all,
Just wondering if anyone had come across this.
I'm trying to configure a 3com AP (8760)to carry different SSIDs on multiple vlans. The switchport is configured as a trunk (dot1q). Each virtual ap on the AP is configured with the correct vlan id. vlan support is enabled on the ap. The virtual ap which runs on the default vlan (vlan 1) works perfectly. Any others don't, if I look at the vlan table, it doesn't show anything other than vlan1 being active on the trunkport.
Any ideas appreciated.
