Guest User SNMP Traps
Answered Question
May 29th, 2008
Hi all,
I run into a confusing behavior. When I use the Lobby Amabassador to add/delete an Guest User with limited life time I get a SNMP Trap (thats what i want) but when I add an Guest User with unlimited life time I never got a SNMP trap, wether the user is added or deletet by the Lobby Ambassador.
I dubble-checked that, with and without Lobby Ambassador Defaults, but I found no reason for that behavior.
Do you have any ideas? Maybe run into the same problem?
Best regards
Peter
Correct Answer by pmccubbin about 8 years 7 months ago
Hi Peter,
Please flag this as resolved if it answered your question. Future readers of this forum will then be able to benefit from our collective intelligence. Thanks.
Best,
Paul
Overall Rating: 5 (2 ratings)
kannancisc Sat, 05/31/2008 - 07:41
Hi Peter,
could you tell me which wcs version you are using?.there is a bug where u won't receive any trap when you create guest user with unlimited time frame.so don't confuse yourself.
krengasw Sat, 05/31/2008 - 10:32
Hi Peter,
yes.it is a bug exists in wcs.when guest user was created with unlimited life time,wcs won't get any trap .i hope this will resolve your problem.
weymannpe Sun, 06/01/2008 - 09:18
Hi krengasw,
thanks for your answer.
Do you know the BugID to this issue.
Many thanks!
Peter
krengasw Thu, 06/05/2008 - 08:58
Hi Peter,
sorry.i donot know bug id.This bug is from controller since wlc fails to send trap to wcs.
Correct Answer
pmccubbin Thu, 06/05/2008 - 09:17
Hi Peter,
Best,
Paul
Trending Topics - Security & Network
