very urgent --GRE tunneling
May 29th, 2008
very urgent -- will cisco GSR 12000 Series support GRE tunneling
shiva_ial Thu, 05/29/2008 - 02:51
will it support by default or i should insert some tunnel line card.
shiva_ial Thu, 05/29/2008 - 20:53
i have my colleagues saying 12000 GSR doesnt support GRE Tunneling ? there are some it so.
do anyone confgiured on GRE tunnel on GSR.
ashok_boin Thu, 05/29/2008 - 21:46
Hi Shiva,
Yes, it needs a card to enable GRE tunneling.
It's there in the same document in prerequisites section.
Dedicated Line Card Required
In order for a GRE tunnel on a Cisco 12000 series Internet router to come up, a Cisco 1-port OC-48 POS line card (tunnel server card) must be installed.
Apart from this, there are no other limitations as far as I know.
shiva_ial Fri, 05/30/2008 - 00:25
hi ashok,
do you use GRE tunneling on your 12000 series router or you are sharing your knowledge expertise.
