Migration
May 29th, 2008
Dear Seniors,
We have the 2600 series router and 2 nonmanageable switch,
Now we want to connect 2 Cisco 2690 series switch we assigned the ip for both manageable switch and we are not creating any VLAN.we want to transfer the network cable to cisco switches from the nonmanagable switch without distributing the network.
How I can do this task with out distributing the network.after finishing this task i will not use the old switc.which is nonmanagable..
spremkumar Thu, 05/29/2008 - 03:22
Do you have enough ethernet ports on the router to connect the switches ?
BTW how the switches are getting connected at this point of time.
are they getting connected independently or through another switch ?
what about the availability of the ports on the patch panel.
if you are planning for a migration without any major downtime then you need to consider all these points in mind.
regds
