[ERR]crypto map WARNING: This crypto map is incomplete
waaelnady
i have PIX 501 ver6.3(5) when i setup VPN i get this error message
WARNING:This crypto map is incomplete to remedy the situation add a peer and a valid access-list to this crypto map.
although it seems fine in sh conf command
but tunnel is not started
when i review log i found
sa_request,ISAKMP Phase 1 exchange started
Put the following command on the PIX and try again:
isakmp identity address
Also please double check the pre-shared keys on both ends (make sure there are no spaces).
If it still does not work, please post log of
debug crypto isakmp 127
Farrukh
11 Replies 11
Jon Marshall
This is nothing to worry about if when you do a "sh crypto map" you don't get the error. It is just an annoying configuration messages where when you create a crypto map it then prompts you to add a peer and an access-list which you were going to do anyway :-).
If however this still shows when you run "sh crypto map" you have probably missed a part of the config.
Jon
thanks for your reply
but no traffic between the hosts yet
any ideas what causing problems with this tunnel
when i check log i see:
sa_request
ISAKMP Phase 1 retransmission
Can you try some debugging on the pix ie.
debug crypto isa
debug crypto ipsec
and post the output.
Jon
kindly send outputs of following show commands for troubleshooting:
sh run isakmp
sh run crypto ipsec
sh run crypto map
i could successfully establish VPN with another FW cisco 501 6.3
but still can't fix my dilemma which i connect to Huawei Eudemon 500‎
sh isakmp
PIX Version 6.3(5)‎
interface ethernet0 10full
interface ethernet1 100full
nameif ethernet0 outside security0‎
nameif ethernet1 inside security100 ‎
access-list inside_outbound_nat0_acl permit ip host internal IP host name remote internal IP1‎
access-list inside_outbound_nat0_acl permit ip host internal IP host name remote internal IP2‎
access-list outside_cryptomap_100 permit ip host internal IP host remote internal IP1‎
access-list outside_cryptomap_100 permit ip host internal IP host remote internal IP2 ‎
global (outside) 1 interface‎
nat (inside) 0 access-list inside_outbound_nat0_acl
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac ‎
crypto ipsec security-association lifetime seconds 3600‎
crypto map outside_map 100 ipsec-isakmp
crypto map outside_map 100 match address outside_cryptomap_100‎
crypto map outside_map 100 set peer remote peer
crypto map outside_map 100 set transform-set ESP-3DES-SHA
crypto map outside_map 100 set security-association lifetime seconds 3600 kilobytes 1843200‎
crypto map outside_map interface outside
isakmp enable outside
isakmp key ******** address remote peer netmask 255.255.255.255 no-xauth no-config-mode ‎
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash sha‎
isakmp policy 20 group 2‎
isakmp policy 20 lifetime 86400‎
sh crypto map
Crypto Map: "outside_map" interfaces: { outside }‎
Crypto Map "outside_map" 100 ipsec-isakmp
Peer = remote peer
access-list outside_cryptomap_100; 2 elements‎
access-list outside_cryptomap_100 line 1 permit ip host 10.102.0.11 host remote internal IP1 ‎‎(hitcnt=14) ‎
access-list outside_cryptomap_100 line 2 permit ip host 10.102.0.11 host remote internal IP2 ‎‎(hitcnt=6) ‎
Current peer: remote peer
Security association lifetime: 1843200 kilobytes/3600 seconds‎
PFS (Y/N): N
Transform sets={ ESP-3DES-SHA, }‎
Crypto Map: "set" interfaces: { }‎
any ideas for this
i thought that if i could start tunnel manually would help
how to use manual key negotiation ? if it supported by pix 501
I already posted on the other thred, Manual IKE is not supported on 501 AFAIK. Can you please post the output of:
debug crypto isakmp
debug crypto ipsec
debug crypto engine
Farrukh
ISAKMP (0): beginning Main Mode exchange
crypto_isakmp_process_block:src:Remote FW IP, dest:MY FW IP spt:500 dpt:500
OAK_MM exchange
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 20 policy
ISAKMP: encryption 3DES-CBC
ISAKMP: hash SHA
ISAKMP: default group 2
ISAKMP: auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
ISAKMP (0): atts are acceptable. Next payload is 0
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_FQDN
return status is IKMP_NO_ERROR
OAK_MM exchange
ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
ISAKMP (0): ID payload
next-payload : 8
type : 2
protocol : 17
port : 500
length : 31
ISAKMP (0): Total payload length: 35
ISAKMP (0): retransmitting phase 1 (0)...
ISADB: reaper checking SA 0xb6a704, conn_id = 0
ISAKMP (0): retransmitting phase 1 (1)...
ISAKMP (0): retransmitting phase 1 (2)...
ISAKMP (0): retransmitting phase 1 (3)...
ISAKMP (0): retransmitting phase 1 (4)...IPSEC(key_engine): request timer fired: count = 1,
(identity) local= MY FW IP, remote= Remote FW IP,
local_proxy= 10.102.0.11/255.255.255.255/0/0 (type=1),
remote_proxy= 10.71.161.15/255.255.255.255/0/0 (type=1)
ISAKMP (0): deleting SA: src MY FW IP, dst Remote FW IP
ISADB: reaper checking SA 0xb6a704, conn_id = 0 DELETE IT!
VPN Peer:ISAKMP: Peer Info for Remote FW IP/500 not found - peers:0
IPSEC(key_engine): request timer fired: count = 2,
Farrukh
Man y are genus, it worked ‎
I have tried this command a few days ago from SSH console but it make nothing I ‎don't know why but later I have read IKE troubleshooting I found the same command ‎I tried it from pix interface it worked
Only one last thing how to change between aggressive and main mode ?‎
Dear Wael, I'm glad you have it working now :)
I'm not aware of any such command on the PIX 6.x. On 7.x and above you can use this command:
crypto isakmp am-disable
Farrukh
