CWLMS 3.0.1 Network Topology Ver 5.0 PPP Multilink Virtual-Access
Answered Question
May 29th, 2008
Is there a way for the Network Topology View to show Virtual-Access Links? I am using PPP Multilink with 2 T.15 interfaces and the links do not show up in the map. Maybe because it uses CDP, and CDP does not work with Virtual-Access links. Anyhow, how can I get the links to show in the map?
Correct Answer by Joe Clarke about 9 years 1 month ago
This is not possible. You must be able to run CDP across links for them to appear on the Topology Map. There is no way to manually add links.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 05/29/2008 - 08:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
THOMAS CARROLL Wed, 06/11/2008 - 07:00
We decided to eliminate the PPP multilink and configure the two T1.5s as serial P-P links. The show cdp neigh commands show the two links, but in the topology map, only of the two serial interfaces display. Any clue why ? I have rediscovered the devices a couple of times manually and the normal schedule discovery.
Joe Clarke Wed, 06/11/2008 - 10:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't follow. Can you post a screenshot illustrating what you're seeing on the map?
Joe Clarke Wed, 06/11/2008 - 11:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the show cdp nei detail output from both devices. Also, I see two Serial2M links are on your map. Do you have another T1 PPP link? If not, if you click on this checkbox to highlight the links, do you see two highlighted lines, or just one?
THOMAS CARROLL Wed, 06/11/2008 - 13:34
See the show cdp nei det in the attachment. To answer your question, yes, I do have other PPP multilink circuits configured in the network. I have only changed just one of the PPP Multilinks at this point. Just a note..If I highlight the Serial2M check box, the map show many of the links that are plan old t1 point to point. I do not know where the Serial2M reference comes from.
Joe Clarke Wed, 06/11/2008 - 21:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post an snmpwalk from both devices for .1.3.6.1.4.1.9.9.23.1.2.1 and ifDescr.
Joe Clarke Thu, 06/12/2008 - 07:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like you may have found a bug or limitation in Campus Manager. This output looks good. Unfortunately, I don't have a dual PPP setup handy to test this. Therefore, I suggest you open a TAC service request with the information you've collected thus far.
