E1 R2 Problem Fax
wilsonsant
Level 6
Level 6
Hi Guys,
Our Customer have any sites and the sites with FXO the Fax work. There is a site that we have E1 R2 the fax don't work, appear the message "communication error". Ask, there is any specific configuration in the Gateway or ATA for the fax work?
Thank You,
Wilson
9 Replies 9
ebreniz
Level 6
Level 6
If H323 connection between the two AS5300 gateways is G.723x or G.729x, the FAX always fails to transfer the FAX message to remote FAX machine. If I set Codec G.728(16kbps) or G.726 (whatever Spec) on Local Dial-peer voip, the local FAX never transfer to final FAX machine. ( Local FAX often detect response tone(beep) from remote FAX, But it fails always with communication error message from remote FAX.
Hi Ebreniz,
I am sorry I don't understando that you speak. The solution is CallManager 5.1.1 and any sites have Gateway 2811 with E1 R2 and the ATA connected in Switch in a one side and tax connected in the ATA.
Thank You,
Wilson
Please send output of "show controllers e1", you might have slips prevent the fax to work.
That is due to lack of "network-clock-participate" and "network-clock-select" commands.
Hi Bevilacqua,
Follow below the configuration of the Gateway and Show Controller E1.
AltoAraguaia_Bio# sh run
Building configuration...
version 12.4
hostname AltoAraguaia_Bio
boot-start-marker
boot system flash c2801-ipvoicek9-mz.124-15.T3.bin
boot-end-marker
enable password xxx
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
ip dhcp relay information option
no ip dhcp use vrf connected
ip dhcp excluded-address 10.3.0.0 10.3.0.10
ip dhcp excluded-address 192.168.232.1 192.168.232.100
ip dhcp excluded-address 192.168.232.114
ip dhcp pool alt
network 192.168.232.0 255.255.255.0
option 150 ip 10.0.1.2 10.0.1.1
default-router 192.168.232.180
dns-server 192.168.1.15 192.168.3.250
no ip domain lookup
voice-card 0
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
voice class codec 1
voice translation-rule 1
rule 1 /^0\([38]00\)/ /0\1/
rule 2 /^0\([^0].*\)/ /\1/
rule 3 /^00\([^0].*\)/ /014\1/
rule 4 /^000/ /0014/
voice translation-profile Local_DDD_DDI_0800_0300
translate called 1
archive
log config
hidekeys
controller E1 0/0/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
country brazil
answer-signal group-b 1
interface FastEthernet0/0
ip address 192.168.232.180 255.255.255.0
ip route-cache flow
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
bandwidth 2048
ip address 172.16.1.198 255.255.255.252
encapsulation frame-relay IETF
ip route-cache flow
load-interval 30
frame-relay interface-dlci 100
frame-relay lmi-type ansi
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.1.197
ip flow-cache timeout active 1
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination 10.100.10.250 63636
ip http server
no ip http secure-server
logging 10.100.10.45
access-list 1 permit any
snmp-server community ng120 RO
snmp-server ifindex persist
disable-eadi
control-plane
voice-port 0/0/0:1
translation-profile outgoing Local_DDD_DDI_0800_0300
cptone BR
timeouts interdigit 3
no mgcp package-capability res-package
no mgcp package-capability fxr-package
sccp local FastEthernet0/0
sccp ccm 10.0.1.1 identifier 1 priority 2
sccp ccm 10.0.1.2 identifier 2 priority 1
sccp
sccp ccm group 1
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 1 register TRANSCODER_ALT
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
associate application SCCP
dial-peer voice 1 voip
destination-pattern 54..
session target ipv4:10.0.1.2
dial-peer voice 2 voip
preference 1
session target ipv4:10.0.1.1
dial-peer voice 3 pots
incoming called-number .
direct-inward-dial
port 0/0/0:1
dial-peer voice 4 pots
description Chamadas externas
destination-pattern 0T
progress_ind setup enable 3
progress_ind progress enable 1
port 0/0/0:1
forward-digits all
dial-peer voice 5 pots
description Chamadas para nzmeros de emergjncia
destination-pattern 1..
port 0/0/0:1
forward-digits all
--More-- !
call-manager-fallback
max-conferences 2 gain -6
transfer-system full-consult
ip source-address 192.168.232.180 port 2000
max-ephones 30
max-dn 30
Don't there is slip error. Thank You for your help,
Wilson
network-clock configuration is OK. Now check:
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/3_0/english/administration/guide/sccp/sccpaapd.html
For how to configure and troubleshoot ATA for fax.
Hi Bevilacqua,
I verify the document that you send for me where it's mention that the codec for E1 should be G.711A-law. In the CCM was G.711u-law, when I change the parameters in the in the option gateway in the CCM, the gateway stop to do external calls.
Wilson
g.711u or a doesn't change. Leave it as it is and check all other parameters.
Hi Bevilacqua,
The problem is occuring because the Fax is a Super 3G and operate with 33,6kbps and the ATA operate with 9,6kbps. I am waiting the Customer change for executed tests.
Thank You,
Wilson
mijiangyun_1818
configing
