WLC Standard/Enable Password
May 29th, 2008
Hi everyone,
Is there such a concept as a standard (read-only) password and enable (config) password functionality on the WLCs?
Would be handy :)
PS. we use a TACACS server for access.
Cheers,
Ken
Overall Rating: 5 (1 ratings)
jeromehenry_2 Thu, 05/29/2008 - 10:02
  • Silver, 250 points or more
You can define read only users, and read and write users (from Management / local management users). The user you create during the initial setup wizard is read/write, you can create others afterwards.
hth
Jerome
kfarrington Thu, 05/29/2008 - 23:20
Many Thx Jerome :)
Can I apply this template to TACACS as all users use TACACS to login?
Many thx once again mate.
Ken
SirAdam_2 Wed, 06/04/2008 - 09:42
What about changing the Login sequence. There is a button on the WLCs and WCS to define which technique is used first, for example Local, then TACACS,...
But it has nothing to do with what Jerome said. It is a different template...
Trending Topics - Security & Network
