I wish to block P2p & IM but, I also deny Yahoo & Google web sites
May 29th, 2008
PIX 515E 7.0 (4)
Following http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808c38a6.shtml
All commands excepted without problems however, yahoo/google are blocked - i can get onto cisco.com. Any ideas?
Here is the config followed by a hasty reload when the company couldn't surf.
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect pptp
service-policy global_policy global
: end
uk-pix#
uk-pix#
uk-pix#
uk-pix# conf t
uk-pix(config)# http-map inbound_http
uk-pix(config-http-map)# content-length min 100 max 2000 action reset log
uk-pix(config-http-map)# content-type-verification match-req-rsp action reset$
uk-pix(config-http-map)# max-header-length request 100 action reset log
uk-pix(config-http-map)# max-uri-length 100 action reset log
uk-pix(config-http-map)# port-misuse p2p action drop
uk-pix(config-http-map)# port-misuse im action drop
uk-pix(config-http-map)# port-misuse default action allow
uk-pix(config-http-map)# exit
uk-pix(config)# class-map http-port
uk-pix(config-cmap)# match port tcp eq www
uk-pix(config-cmap)# exit
uk-pix(config)# policy-map inbound_policy
uk-pix(config-pmap)# class http-port
uk-pix(config-pmap-c)# inspect http inbound_http
uk-pix(config-pmap-c)# exit
uk-pix(config-pmap)# exit
uk-pix(config)# service-policy inbound_policy interface outside
uk-pix(config)#
uk-pix# rel
System config has been modified. Save? [Y]es/[N]o:
Proceed with reload? [confirm]
uk-pix#
Overall Rating: 1 (1 ratings)
smahbub Wed, 06/04/2008 - 13:27
  • Silver, 250 points or more
The document present in the following link describes how to configure the Cisco Security Appliances PIX/ASA using Modular Policy Framework (MPF) in order to block the Peer-to-Peer (P2P) and Instant Messaging (IM), such as MSN Messenger and Yahoo Messenger, traffic from the inside network to the Internet. Also, this document provides information on how to configure the PIX/ASA in order to allow the two hosts to use IM applications while the rest of the hosts remain blocked.
geraghtyconor Wed, 06/04/2008 - 23:25
Thx BUT - that's the link I inserted above!! This procedure ASLO denies my users access to yahoo.co.uk and google.com. I JUST want to deny IM and P2P.
