Malformed syslog message?
Answered Question
May 29th, 2008
  • Gold, 750 points or more
Isn't the second line a malformed syslog, without the Facility and Mnemonic fields? Is this an IOS bug?
May 29 08:37:13.110: %OIR-SP-6-INSPS: Power supply inserted in slot 2
May 29 08:37:13.110: SP: unknown power supply in slot 2
May 29 08:37:14.066: %OIR-SP-6-REMPS: Power supply removed from slot 2
Correct Answer by Joe Clarke about 8 years 10 months ago
Buginf logging is enabled by default. You'd have to turn it off with "no logging buginf".
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 05/29/2008 - 07:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is most likely not a syslog message at all, but a "buginf" message. Buginf messages do not have to correspond to the syslog format scheme. What version of code is this?
Joe Clarke Thu, 05/29/2008 - 08:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Confirmed. This is a buginf message. This message is displayed when the PS inserted is not a known PS type for the device. This is not a good thing. Either the code needs to be updated, the PS is bad, or the PS cannot be used in this device.
yjdabear Thu, 05/29/2008 - 09:07
I don't see "logging buginf" configured. Is it enabled implicitly by default, in this version or all IOS? Does it get sent to the syslog server anyway? The troubling part is a proper syslog "%C6KPWR-SP-3-PSUNKNOWN: Unknown power supply in slot 2" does not get generated until 2-8 mins after those three lines appeared.
Correct Answer
Joe Clarke Thu, 05/29/2008 - 09:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
