upgrade from 6.0.1 to 6.1.2
May 29th, 2008
Hi all, trying to upgrade.
i.e. I go to OS Management on the browser, select upgrade, select DVD and / for the root, then NEXT.
It identifies the file, I select NEXT, then it comes back with the following:
[/usr/bin/sudo/usr/local/bib/base_scripts/upgrade_validate_file.shmethod=localsource_dir=/file_name=UCSInstall_UCOS_6.1.2.1000-13.sgn.iso] did not generate the appropraite result file.
now I did do the md5sum on the file and got the desired result, so i've no idea why it doesn't appear to like this.
Any ideas out there?
ta
Grant
thisisshanky Thu, 05/29/2008 - 07:53
  • Purple, 4500 points or more
Grant, did you merge the two ISO files and compare the md5 ?
reidg Thu, 05/29/2008 - 08:07
Hi Sankar,
yes I downloaded both files then merged then ran the md5sum utility, got the right checksum.
I was wondering, when I downloaded the file I did it on a windows pc and ran the merge on it, then the md5sum and burned a dvd. however the servers are Linux. I assumed this shouldn't make any difference as its only a lump of data thats being merged, shouldn't matter what os is doing the merging, right?
thisisshanky Thu, 05/29/2008 - 08:19
I have had issues with merging files before. the md5 of individual files will match, but after combining, it wont match at all. I dont think the windows/linux issue matters, but the last time i did a 6.0 to 6.1 upgrade, i had to run it via CLI.
reidg Fri, 05/30/2008 - 02:58
Found out what is was, I hadn't burned the image as an iso onto the disc, i'd done it just as a lump of data. Once burned as iso worked fine.
