Renaming an interface on a FWSM
May 29th, 2008
i need to rename an interface for one of my DMZ's, if i just use the nameif command with the new name, will that change the name for the access-group and the routes.
Syed Iftekhar Ahmed Thu, 05/29/2008 - 09:49
No worries
It will change the name for all the relevant commands. Such as
access-group
Nat related commands
telnet
ssh
route
etc....
Syed
GrumpyBear Tue, 06/03/2008 - 11:59
Ummm,
Very bad advice especially if you are running 3.2.
I did that a while ago and just applying "nameif" doesn't change the name. If you remove the existing name and apply a new one using "no nameif oldname" "nameif new name" "exit" it removes your access-group commands associated with that interface
