Need help configuring QOS
May 29th, 2008
Hi I need help configuring QOS on cisco 3750 switch. I was previously using 2950 and that needs replaced by these 3750 and the QOS configured on the new 3750.
Global configuration
mls qos map cos-dscp 0 8 16 46 46 46 48 56
mls qos
Interface configuration
interface FastEthernet1/0/1
switchport trunk native vlan 22
switchport mode trunk
switchport voice vlan 22
mls qos trust cos
storm-control broadcast level 10.00
spanning-tree portfast.
Now I didn't see any DSCP marking when I capture packets using ethereal
Overall Rating: 5 (1 ratings)
michael.leblanc Thu, 05/29/2008 - 09:56
There is nothing in your configuration to indicate that you have "attempted" to configure packet marking, queueing, or any of the other key aspects of QoS.
It "appears" as though you expect someone to do all the work for you.
You need to first define what your requirements are, before you can commence with QoS configuration.
I suggest you do a search on the Cisco web site for a document titled "Quality of Service Solutions Configuration Guide"; do some reading; define your requirements; and then return with a request for assistance following some initial attempts to configure QoS.
No offense intended.
Arvind kumar Fri, 05/30/2008 - 05:59
I have a lot consideration on 3750 but no avail. I have configured the swtich as per the configuration given above. I didn't get the desired DSCP value on packets captured on ethereal. I have qos markings on the IP Phone and port is trusting on cos while the trunk is trusting on dscp and qos is globally enabled on the switch. I am able to capture packets with dscp values on the the earlier 2950 switches
Arvind kumar Tue, 06/10/2008 - 06:27
If I have trust qos dscp on trunk port and capture the traffic of this trunk will it has qos marking . Is qos marking on trunk while packets are entered/exit. Thanks
