POE and 7940 ip phone
May 29th, 2008
I have a 2811-ac-ip with a NME-16ES-1G-P card install I can get a 7941 to power up, but the phone I have are a 7940 and they will not power up. The swith is running 3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5. Please help
thisisshanky Thu, 05/29/2008 - 08:17
Have you tried powering this particular phone on another inline power switch ? Just wondering if its a bad phone?
Rob Huffman Thu, 05/29/2008 - 08:32
Hi Douglas,
It sounds like this bug (Thanks Met!);
CSCsi70300 Bug Details
NME Etherswitch Service Module Not Detecting Pre-Standard Devices
Symptom:
Pre-Standard POE devices are not powering up, link is down/down.
Conditions:
PreStd POE device must be connected to Etherswitch Service Module (ex. NME-16ES-1G-P) running 12.2(35)SE2.
Workaround:
Downgrade IOS to 12.2(25)SEE3
Further Problem Description:
Althought the NME runs 3750 IOS, the problem is not seen on a 3750 switch.
The IEEE 802.3af devices function fine (ex. 7961, 7941), only Pre-Std are affected.
Hope this helps!
Rob
qwest5555 Thu, 05/29/2008 - 10:56
Downgraded switch to IOS to 12.2(25)SEE3
Everything work great !!
Thnaks
Doug
Shane Kirby Thu, 05/29/2008 - 11:25
If you need to run a later version of IOS for other features this defect is resolved in 12.2(40)SE or later.
mattman04 Thu, 05/29/2008 - 14:18
I'm seeing similiar behavior on my Cisco 1801.
POE - power supply is connected and POE LED is green, but when I connect 7941 phone it does not power up.
I'm running IOS Version 12.4(11)T4.
The inline power config is set for auto on all ports and a 'show power inline' sees an 80 watt power supply, but nothing allocated to any of the ports.
Any thoughts would be greatly appreciated.
Thanks...matt
