How would I copy then upgrade the firmware on a 3750 via the Console cable?
May 29th, 2008
All,
How would I copy then upgrade the IOS on a 3750 via the Console cable? I have a switch I want to add to a stack and I want to put that same IOS version on it.
When I put it on the stack with a different version, I received a version mismatch error. So I tried the archive copy-sw /overwrite /dest 2 1, but received the errors:
ERROR:Malformed `info' file.
ERROR: Image is not a valid IOS image archive.
glen.grant Thu, 05/29/2008 - 09:18
  • Purple, 4500 points or more
You should be able to copy from the stackmaster to the new switch. If for some reason you can't get a free tftpserver to run on your laptop and use that to transfer your image , it will be a lot faster than using xmodem to transfer the file.
