Inline card connectivity
May 29th, 2008
Original LAN switch GE port configured 100/full and connected to router FE port (100/full) directly.
Now we are setting WAE 612 in between both devices and configured InlineGroup 1/0 to 100/full, but the router FE IP cannot be ping this moment.
When I remove 100/full settings from WAE InlineGroup 1/0, then the IP of router FE port can be ping to. But WAE InlineGroup (LAN and WAN) are showing 100/half.
Is it affected by the cable issue? Not using crossover cable to plug into Router FE port and WAE InlineGroup (WAN port).
Overall Rating: 5 (2 ratings)
