Guest wireless routed to a different ISP?
Answered Question
We have a a 4402 with several WLANs including a Guest WLAN. Is it possible to route all traffic from the Guest WLAN to a separate ISP? Guest is setup on a different VLAN. Would this be configured in the 4402, the switches, or our ASA device?
Thanks in advance for your help.
JK
Correct Answer by Scott Fella about 9 years 19 hours ago
Jerome is right, or else you can disable LAG and configure port 1 as the management and ap-manager and connect that to you infrastructure and then assing the ssid to port 2 which will be connected to a switch with your other isp or dsl connection.
Correct Answer by jeromehenry_2 about 9 years 20 hours ago
On the controller, I would send the guests to a specific interface, which is a specific VLAN/subnet. Then I would route this subnet to the second ISP from your router or layer 3 switch...
hth
Jerome
Overall Rating: 5 (2 ratings)
Correct Answer
jeromehenry_2 Thu, 05/29/2008 - 10:01
  • Silver, 250 points or more
hth
Jerome
Correct Answer
Scott Fella Thu, 05/29/2008 - 10:24
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
