Cannot ping or telnet internal PIX 501 Interface
Answered Question
May 29th, 2008
I have a VPN link from a PIX501 at our remote office to a ASA5510 at our main office.
Remote Office 192.168.3.0/24, Main Office 10.0.0.0/24.
A client on the 10.0.0.0/24 network cannot ping, http or telnet the PIX501 internal interface 192.168.3.1 although can connect to clients OK e.g. 192.168.3.2.
The PIX config is below can anyone spot what is causing this, Thanks in advance.
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxxxx encrypted
passwd Xxxxxxx encrypted
hostname xxxxxxxx
domain-name xxxxxx.com
clock timezone LINT 14
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
name 10.0.0.0 OfficeHQ
access-list inside_nat0_outbound permit ip 192.168.3.0 255.255.255.0 OfficeHQ 255.255.255.0
access-list outside_cryptomap_60 permit ip 192.168.3.0 255.255.255.0 OfficeHQ 255.255.255.0
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.248
ip address inside 192.168.3.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location OfficeHQ 255.255.255.0 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.3.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto map outside_map 60 ipsec-isakmp
crypto map outside_map 60 match address outside_cryptomap_60
crypto map outside_map 60 set peer x.x.x.x
crypto map outside_map 60 set transform-set ESP-3DES-MD5
crypto map outside_map interface outside
isakmp enable outside
isakmp key ******** address x.x.x.x netmask 255.255.255.255 no-xauth no-config-mode
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
telnet 192.168.3.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
dhcpd address 192.168.3.2-192.168.3.10 inside
dhcpd dns 10.0.0.243 4.2.2.2
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain xxxxxxxxxxx
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxxxxxxxxx
Correct Answer by srue about 9 years 1 month ago
that's an older OS than what i'm used to, is the command "management-access inside" supported?
Overall Rating: 5 (1 ratings)
Correct Answer
srue Thu, 05/29/2008 - 10:44
  • Blue, 1500 points or more
shaw.chris Fri, 05/30/2008 - 04:00
Thanks for your help, the ssh access worked,
I have updated the PIX to 6.3(5) and issued the management-access inside command but still cannot get in for some reason.
srue Fri, 05/30/2008 - 04:09
since you just did a major OS upgrade on it, can you repost the config?
shaw.chris Mon, 06/02/2008 - 08:20
The "management-access inside" command did actually do the trick, Thanks for your help.
