ccm 6.1 - Need to supress outbound CLID business name
May 29th, 2008
environment is a 6.1 cluster utilizing a PRI for calls, mgcp controlled from router. Issue is when a call outbound is placed it shows the office name and number in caller id. The number is not the problem it is the business name that we want to get rid of. Is their a way to do this on ccm?
Cheers.
Overall Rating: 4 (3 ratings)
Brandon Buffin Thu, 05/29/2008 - 12:40
  • Purple, 4500 points or more
The caller ID name is not being sent from CCM, but is being presented by the telco of the recipient of the call. They do a database lookup based on the calling number to determine the name to display. In this case, you would need to contact your providor to get them to make your name unlisted or change it to something different. Once they update their database, it will propogate to other providors.
Hope this helps. If so, please rate the post.
Brandon
hbarrera2 Thu, 05/29/2008 - 12:56
bbuffin,
So their is nothing I can do on the callmanager to supress this?
Thanks!
Brandon Buffin Thu, 05/29/2008 - 12:57
No, as it is not being produced by CCM.
Brandon
hbarrera2 Thu, 05/29/2008 - 13:04
Gotcha!
Thank you very much for your input, its appreciated.
Cheers.
I agree and disagree with the others. Yes the CLID is a function of the LEC, but you have control of it from your line settings.
You can put the below line in to block ALL CLID outbound for that shared line
>>>dial-peer voice 1000 pots
>>>destination-pattern 8T
clid restrict
>>>port 0/1/0:15
If this is works for you please rate my answer.
Cheers,
Royce Lindsey, CCVP
Okay since you have a PRI, you are controlling the CLID and CLIN you cannot do a peer to block FXO since the telco does handle that part unless you do a *67 in the outbound pattern.
On a Pots PEER-
Only external calls
>dial-peer voice 10 pots
>clid strip - to block only the number
>clid strip name - to block only the name
To send only caller name
telephony-service
caller-id name-only
To block caller id on a call by call basis
>telephony-service
>caller-id block code *67
Brandon Buffin Fri, 05/30/2008 - 04:32
According to the original poster, they are using MGCP, so any configuration under a dial peer would not be relevant. Also, they are using CUCM, so any configuration under "telephony-service" would also not be relevant as this is configuration for CME.
Brandon
Rob Huffman Fri, 05/30/2008 - 05:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Guys,
I have seen this before and in our neck of the woods you have to pay $$ for full Name/Number display on PRI's. The default if you don't add the extra functionality is for the Telco provider to populate all Outgoing calls with the Corporate Name and Number. Brandon +5 points for this assessment. Royce +5 points for your good answers as well (I think you probably just missed the MGCP reference :)
Take care,
Rob
