upgrade from IPCC 4.0(5) to ccx 5
May 29th, 2008
I have a running enviroment that consists of a ccm 4.1(3) cluster and an IPCC 4.0(5) cluster in a 4 server HA model deployment. I'm going to upgrade to UCM 6 so i need to upgrade the IPCC as well to UCCX 5.
My question:
how can this be done without any loss in configuration on the IPCC? as i have read that there is no direct upgrade path from IPCC 4.0 to UCCX 5.
Overall Rating: 4 (1 ratings)
Chris Deren Thu, 05/29/2008 - 13:46
You need to export all files including scripts/docuemnts/prompts and take screen shots of all configuration. There is no way around it.
mohamed_ali Thu, 05/29/2008 - 14:02
This is very bad as this cluster is running a 24*7 call center. what is the best way to handle this u think?
mohamed_ali Thu, 05/29/2008 - 14:53
how about the agent licenses? how will i move them to the new servers?
Chris Deren Thu, 05/29/2008 - 16:15
When you request the media for upgrade through PUT Cisco ships a new PAK for UCCX 5.0, simply register this PAK and you'll have your new license.
HTH, please rate all useful posts!
