How to setup SIP and H.323 test lab?
May 29th, 2008
Appreciate if anyone can help me how to setup a sip/h323 trunking lab. Im having a hardtime in configuring my router and pix 722. My current setup is PBX-router-pix-router. I want to build a test lab first then if is success, ill setup this for production.
Overall Rating: 5 (2 ratings)
paolo bevilacqua Thu, 05/29/2008 - 17:32
  • Hall of Fame,
    Founding Member
Do you have set a proper gre tunnel across routers ?
That will make everything easier. PIXs and FWs are a problem for voip so it's better to use tunnel whenever possible and the will be be unable to disrupt traffic as usually happens otherwise.
jong_r0602 Thu, 05/29/2008 - 22:45
i dont have a gre tunnel rightnow, appreciate if you can help me also to setup a gre tunnel across my routers.
Thanks for your response,
-jong
jong_r0602 Mon, 06/02/2008 - 18:01
Thanks guys to your help, im now starting to build my test lab. I'll post my question immediately if any.
- jong
jong_r0602 Tue, 06/03/2008 - 18:33
How about my dial-peer config for sip and h.323. Do i need an extra config for my PIX also?
Jong
