VLAN Interface
jaweed123
How to create a VLAN interface which contains an IP address that acts as a gateway for all the hosts for that VLAN.
Thanks and Regards
muca
Level 3
Level 3
This urls should give you some help...
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml#maintask1
SwitchLayer3(config)#interface Vlan2
SwitchLayer3(config-if)#ip address 10.1.2.1 255.255.255.0
SwitchLayer3(config-if)#no shutdown
SwitchLayer3(config)#interface Vlan3
SwitchLayer3(config-if)#ip address 10.1.3.1 255.255.255.0
Create management vlan interface on all your switches, let's say 200
SwitchLayer3(config)#interface Vlan200
SwitchLayer3(config-if)#ip address 10.1.200.1 255.255.255.0
Switchlayer2(config)#interface Vlan200
Switchlayer2(config-if)#ip address 10.1.200.2 255.255.255.0
Switchlayer2(config-if)#no shutdown
Default gateway of your layer 2 switches
ip default-gateway 10.1.200.1
shiva_ial
what is the switch model you are trying to create ?
rgds/shiva
muca
Level 3
Level 3
Thank you, It worked.
