Failed to login Cisco Unity Connection Administration Console
May 29th, 2008
Everytime I key in the correct username and password and then click login, it just shows the login page again. I am sure the username is correct because if I key in wrong username or password, it can prompt error. I have tried to re-image the Unity Connection and it works properly. However, after working for some days, the problem happens again.
Please help!!
rore Tue, 11/11/2008 - 03:34
I have the same problem, did you come up with a solution ?
