Recording prompts using IP phone
Answered Question
May 30th, 2008
Windows recorder is far from ideal for recording prompts. Can someone tell me how to record prompts using IP phone. (CCX5).
Ta
Rich
Correct Answer by adignan about 8 years 12 months ago
You can use the attached script for recording your prompts. If you name your scripts numerically (5000.wav, etc.), you can use it for ongoing maintenance as well.
Overall Rating: 5 (4 ratings)
tomide_ccie Fri, 05/30/2008 - 07:24
i usually do this using unity, if you have unity, from a mailbox or call handler , configure unity to ring a specific phone,do your recording, save the wave file to your desktop and upload to CRS.
Abdulbaseer Mohammed Fri, 05/30/2008 - 21:51
  • Silver, 250 points or more
What Tomide suggested about unity is pretty popular many customers use the same approach.
One other way is to write script for collecting prompts and do your recording put that to a particular file and that should be the same but its cumbersome for few.
Please rate helpful posts.
Good luck,
Baseer.
richb1971 Sat, 05/31/2008 - 00:02
Cheers Tom. Its for customer use so would like to avoid moving files around.
Baseer,
A script was what I was after. Do you have an example of one?
Rich
kent.roberts Sat, 05/31/2008 - 11:27
What options do you have available to you? IVR, CVP, vxml? (and version).
richb1971 Sun, 06/01/2008 - 03:30
Got CCX5 Enhanced version. Has anyone got a script that will allow users to record their own prompts and store them on CCX server?
Ta
Rich
Correct Answer
adignan Sun, 06/01/2008 - 15:13
  • Blue, 1500 points or more
Abdulbaseer Mohammed Mon, 06/02/2008 - 23:50
Andy,
Thanks bud.
Rich you have the best help on planet :)
I was busy with client. Take Andy's file it should address your need.
Good luck and please rate helpful posts.
