ISDN card issue
Answered Question
May 30th, 2008
Hi all,
Can anyone please confirm that the following card can be used for a ISDN PRI for voice connection: VIC2-2BRI-NT/TE
Correct Answer by paolo bevilacqua about 9 years 1 month ago
Ni, it cannot be used for PRI. You need VWIC or VWIC2, and a number of DSP resurce depending on how many channels you have active.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Fri, 05/30/2008 - 02:45
  • Hall of Fame,
    Founding Member
Seifeddine-Tlili Fri, 05/30/2008 - 08:33
Sorry but what did you mean by you may need to upgrade the IOS on the router?
so to sum what you said i can use it for PRI in the event if i upgrade the IOS but the card has the Name BRI so it's only usable for BRI connection not PRI thanks for replying soon i need this kind of information :)
