May 30th, 2008
Hi all, what will be the implications of clearing the arp on my l3 switch, can you clear it per vlan ? also do the arp entries have a lifetime ?
ralphcarter Fri, 05/30/2008 - 12:17
#clear arp-cache [interface xxx]
The [interface xxx] is optional where you can clear arps from an interface.
If you clear the arp cache, you will have a slight delay as your L3 routing engine forwards new arp requests to its connected vlans to locate mac-addresses.
Its good to clear the arp when troubleshooting problems related to reconfiguration.
shiva_ial Sun, 06/01/2008 - 21:28
in normal cases arp cache timeout period is 4 hrs
you can also get confirmed by using show int (your interface) command.
bvsnarayana03 Sun, 06/01/2008 - 21:35
As mentiond in previous post, arp lifetime is default of 4 hrs. Chek the output below.
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
ARP cache is cleared when existing devices are replaced with similar IP address. e.g. you replaced a switch with new onw but same UIP adress. in this case the new mac-add has to be updated in the arp but it doesnt get reflected automaticlly due to the large timeout period. In such cases, clear arp cache is a good option.
