Dial-peer configuration
Answered Question
May 30th, 2008
Is there a way to group together multiple IPs under one dial-peer?
For example, 192.168.1.0/24
Instead of creating a separate dial peer for each IP within the Class C, is it possible to group them together into one dial peer? This is for inbound dial peer voice and pots configuration.
Correct Answer by Paolo Bevilacqua about 8 years 9 months ago
For inbound voip DP, it is not necessary to specify any address.
For inbound pots DP, IP does not apply at all.
What problem are you trying to solve ?
Overall Rating: 5 (2 ratings)
Correct Answer
Paolo Bevilacqua Fri, 05/30/2008 - 09:06
  • Hall of Fame,
    Founding Member
apendhar Sat, 05/31/2008 - 13:38
  • Cisco Employee,
Inbound side doesnt care for IP addr, just specify the incoming called number, session protocol, codec, dtmf-relay, and any other specific parameter.
