Upgrade assistant question
May 30th, 2008
Hi all. Is the upgrade assistant the actual upgrade software for a callmanager server? Or is it only checking the health of the server, and does not actually do the upgrade?
mikedurbin Fri, 05/30/2008 - 07:21
Ok, I thought this was right, but Ill answer my own question. They are not the same, the upgrade is different than the upgrade assistant. Thanks.
Jaime Valencia Fri, 05/30/2008 - 07:34
  • Cisco Employee,
  • Hall of Fame,
    2011
you're right, the upgrade assistant is only a health checkup to verify you meet the minimum requirements to jump to the applicable version but it does not apply any patch or anything else, it will tell you if you need something but won't do the install of what you need by itself.
javalenc
if this helps, please rate
