ASA 5505 VPN can't access inside host
Answered Question
May 30th, 2008
I have setup remote VPN access on a ASA 5505 but cannot access the host or ASA when I login using the VPN. I can connect with the Cisco VPN client and the VPN light is on on the ASA and it shows that I'm connected. I have the correct Ip address but I cannot ping or connect to any of the internal addresses. I cannot find what I'm missing. I have the VPN bypassing the interface ACLs. Since I can login but not go anywhere I feel certian I missed something.
part of config below
interface Vlan1
nameif inside
security-level 100
ip address 10.1.1.1 255.255.255.0
ip local pool xxxx 10.1.1.50-10.1.1.55 mask 255.255.255.0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 40 set pfs
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA
crypto dynamic-map inside_dyn_map 20 set pfs
crypto dynamic-map inside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto map inside_map 65535 ipsec-isakmp dynamic inside_dyn_map
crypto map inside_map interface inside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
service-policy global_policy global
group-policy xxxxxxx internal
group-policy xxxxxxx attributes
banner value xxxxx Disaster Recovery Site
wins-server none
dns-server value 24.xxx.xxx.xx
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelall
default-domain none
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout none
ip-phone-bypass disable
leap-bypass disable
nem disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools value xxxxxx
smartcard-removal-disconnect enable
client-firewall none
webvpn
functions url-entry
vpn-nac-exempt none
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
tunnel-group xxxx type ipsec-ra
tunnel-group xxxx general-attributes
address-pool xxxx
default-group-policy xxxx
tunnel-group blountdr ipsec-attributes
pre-shared-key *
Correct Answer by acomiskey about 8 years 10 months ago
You are missing nat exemption for the vpn clients. Add the following and you should be good to go.
access-list inside_nat0_outbound extended permit ip any 192.168.10.0 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
Overall Rating: 5 (1 ratings)
acomiskey Fri, 05/30/2008 - 07:22
  • Green, 3000 points or more
If you can post the config, that would be great.
randyclark Fri, 05/30/2008 - 09:48
I get the banner and IP adress info...
This is what the client log provides...
1 13:45:32.942 05/30/08 Sev=Warning/2 CVPND/0xE3400013
AddRoute failed to add a route: code 87
Destination 172.20.255.255
Netmask 255.255.255.255
Gateway 10.1.2.1
Interface 10.1.2.5
2 13:45:32.942 05/30/08 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: ac14ffff, Netmask: ffffffff, Interface: a010205, Gateway: a010201.
randyclark Mon, 06/02/2008 - 11:01
Here's the latest config... I can connect, get an IP but still cannot access the local host or the firewall. The firewall show that I have a tunnel but I still can't access anything.
Correct Answer
acomiskey Mon, 06/02/2008 - 12:47
a.alekseev Wed, 07/09/2008 - 00:52
  • Gold, 750 points or more
open a new topic, attach configs, give full description of the problem.
