No communication b/w VLANS
May 30th, 2008
Hi All I am having trouble with VLans on Cisco 3550. I am using this switch as standalone device. All the end points and hubs and dumb switches are connected to it. I do have a linksys router which is acting as a gateway.
Here is the configuaration
Ip routing
Fastethernet port 1 - 20 Vlan 1
Fastethernet port 21 - 24 Vlan 2
Int vlan 1
Ip address 192.168.70.2 255.255.255.0
ip access-group 101 in
ip access-group 101 out
no ip directed-broadcast
no ip redirects
int vlan 2
ip address 192.168.74.1 255.255.255.0
ip helper-address 192.168.70.255
ip helper-address 192.168.70.8
ip forward-protocol UDP 4011
no ip redircts
access-list 101 permit ip 192.168.70.1 0.0.0.255 any
access-list 101 permit ip 192.168.74.1 0.0.0.255 any
network 192.168.70.1
network 192.168.74.1
ip route 0.0.0.0 0.0.0.0 192.168.70.1
I really appreciate any help.
mahmoodmkl Fri, 05/30/2008 - 08:09
  • Gold, 750 points or more
HI
Can u change u r access-list to
access-list 101 permit ip 192.168.70.0 0.0.0.255 any
access-list 101 permit ip 192.168.74.0 0.0.0.255 any
btw y r u using the access-list.
there is not need for the access-list if u just want intervlan routing.
Mahmood
athar_iqbal Fri, 05/30/2008 - 08:14
Sure I will apply that. I am using access list to explicitly allow communications because intervlan communication was not working. and Also I am new to Cisco so I am trying to get the best I can do
mahmoodmkl Fri, 05/30/2008 - 08:18
Have u created the vlans.What is default-gateway for u r clients.Seeing u r config there is no need for access-list if u just intend to have intervlan routing.
Mahmood
thotsaphon Fri, 05/30/2008 - 08:22
Hi Athar,
Hopes you already added "Switchport mode accees vlan 2" to all ports of vlan2. Did you?
Please do "sh vlan" and "sh ip route" commands.
Thot
athar_iqbal Fri, 05/30/2008 - 08:36
Yep I did added all the port to Vlan 2 and Sh ip Route does show
192.168.74.0 C
192.168.70.0 C
athar_iqbal Fri, 05/30/2008 - 08:40
Hi Mahmood,
All the client default gateway for Vlan 2 is 192.168.74.1 Which is the Vlan Ip address. All the clients on the Vlan 1 has the default gateway set to 192.168.70.1 which is the address of the Link sys router. Vlan address of the switch is 192.168.70.2 I have DHCP which is in Vlan 1. I am trying to get the dhcp address for all the clients in VLAN2 from Vlan 1. Microsoft DHCP server is already configured with the DHCP scope
thotsaphon Fri, 05/30/2008 - 08:45
OK that's a good explanation.
LinkSys should know about vlan2 network.
Does Linksys has "ip route 192.168.74.0/24 192.168.70.2?
One more thing : It's not a good idea to add your ACls into vlan2 if you want all vlan2 PCs to get dhcp.
It will not work unless you allow bootpc and bootps.
access-l 101 per udp any any bootpc
access-l 101 per udp any any bootps
Thot
mahmoodmkl Fri, 05/30/2008 - 08:48
U need to have the default-gateway for u r clients in vlan 1 as the vlan ip address of the switch,becoz u have created the svi for that vlan on the switch it means it going to do intervlan routing.Under u r vlan interfaces on the switch use
ip helper-address (ip address of the dhcp server)
U cannot get the ip address from the vlanw from vlan1 as they are different broadcast domains.
Mahmood
Wilson Samuel Fri, 05/30/2008 - 09:28
  • Community Spotlight Award,
    Mobile User, July 2015
Have you enabled IP Routing on the switch?
athar_iqbal Fri, 05/30/2008 - 12:36
Yep I did, I am going to test the switch on monday. for Mahmood I already switched my gateway ip and make Vlan address default gateway and I am able to get the IP from the other vlan through IP helper command. It seems to start working. I will try to enhance furthure
