Authentication Issues ACS 4.1.1.23 with AD
May 30th, 2008
hi, I have installed and configured an ACSse 4.1.1.23 to do 802.1x authentication with a Catalyst 3750.
The users from the ACS internal database works fine, but when we try using accounts from the AD, the error showed is "authentication failed" , auth failed code "internal error" .
Jagdeep Gambhir Fri, 05/30/2008 - 11:35
  • Red, 2250 points or more
This seems to be a permission issue. Make sure that service account running remote agent should be a part of domain admin and have special privilege on domain controller, specially act as a part of os and login as server.
Also make sure that acs and remote agent ver are same.
~JG
Do rate helpful posts
