device credential
Answered Question
May 30th, 2008
I want change the credential on all devices
on common services including standard and snmp credential. I have tried to edited all at once. but not successful.still keep the old credential.
Correct Answer by Joe Clarke about 8 years 9 months ago
I just tested this again in CS 3.1.1, and it works. Select all the device you want in DCR, then click "Edit Credentials". Modify the credentials you want to change, then click Finish. They should all be updated.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 05/30/2008 - 08:54
