DHCP service on 3560 Switch
May 30th, 2008
  • Gold, 750 points or more
Hi All,
I need to cross check the documentation, but the question is, will it possible to configure 3560 Switch as DHCP server and assign IPs to only one vlan (not to other on the same switch).
ex: Vlan 20, 30, 40 existing on switch and switch is running OSPF (core switch) with int vla 20/30/40... created. Now I want the switch to be able to provide IPs dynamically to vlan 40 only. Other Vlan PCs got static IPs.
How can I accomplish this..? Please suggest.
Thank you
MS
Overall Rating: 4 (2 ratings)
mahmoodmkl Fri, 05/30/2008 - 08:33
Yes u can do that.
U need to create the dhcp pool for just vlan 40.
Mahmood
royalblues Fri, 05/30/2008 - 08:33
  • Green, 3000 points or more
Define only one DHCP pool on the switch corresponding to the VLAN 40 network.
eg. vlan 40 = 10.10.10.0/24
ip dhcp excluded-address 10.10.10.1 - 10.10.10.10
ip dhcp pool vlan40
network 10.10.10.0 /24
default-router 10.10.10.1
dns-server x.x.x.x
Narayan
mvsheik123 Fri, 05/30/2008 - 08:46
Yeap.. I did long time back on 3750 wanted to make sure it works on 3560 also. Thanks you both for the reply.
MS
